CGNS files contain no data
Old   December 27, 2014, 22:27
Default CGNS files contain no data
ansys_matt is on a distinguished road
I made a big mistake and accidentally had Fluent write the solution files to a transient simulation in cgns format instead of to "CFD-post compatible" which I usually use.
So I loaded the cgns files into cfd-post and all of the saved variable names (velocity temperature, etc) are there, along with the mesh, but all the data is zero. Zero temperature everywhere, zero pressure everywhere, zero everything everywhere.
I double checked that the simulation was good by changing the export to CFD-post compatible and solving for only a few timesteps. The new files do contain the expected data. But I have a multiple day simulation in this cgns format I need to read.
How can I ever see the data? Thanks.
ansys_matt is offline   Reply With Quote
Old   August 19, 2016, 23:22
Jingchang.Shi
aerosjc is on a distinguished road
Did you solve this problem?
aerosjc is offline   Reply With Quote
cgns, fluent
Transient Non-uniform boundary condition with data files hcs129 OpenFOAM 1 April 28, 2014 23:53
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 05:46
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
