PBS fluent parallel batch jobs - Linux/Windows
Old   December 25, 2014, 09:38
Default PBS fluent parallel batch jobs - Linux/Windows
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Dear all;
I was trying to perform a cluster computation for ANSYS Fluent. I ran the job finally without errors using my windows laptop connected to the cluster which runs linux SP2.
So I just thought to share some ideas and errors that I faced during this which will benefit if any one is looking for some guidance in this. I am no expert but I managed to tackle this with thousands of tries and I know how irritating it can be
What I basically did is downloaded Putty and saved a session where X forwading is enabled. Then, I downloaded Xming server and installed it so I can have a GUI in my windows for the linux machine.
First of all try to find the directory in which fluent and lic_admin is installed in the cluster using a FTP client ( I use file zilla).
Then using putty command the program to open lic_admin:
according to what I know fluent is located mostly in:
/(CLUSTER NAME)/ ansys_inc/v145/fluent/bin/fluent
and lic_admin is located in:
/(CLUSTER_NAME)/ansys_inc/shared_files/Licensing/.../lic_admin
if you run the directory line above now after modifying it to your directory
Lic_admin should open ansys license manager and set preference to your user ( academic or license available) once you do it some files will be generated in your user folder in linux which means you got the license preferences. This in turn could mean that you dont need to specify license server in your batch script which you will submit to cluster because license settings will be saved.
Now create the PBS script ( with the specific amount of nodes and cores you wish) and submit it to cluster) ( sample scripts are all over internet)
One more thing, when you submit jobs through PBS and if you view your error file and you keep getting bad tty (file descriptor) it does not mean that this message should be ignored. usually a lot of online help says you can easily ignore this message. but according to what i have gone through it simply means that there is some sort of error in your script and since there is no way of communicating with you it delivers this message.
Regards
shereez234 is offline   Reply With Quote
batch mode, batch runs, fluent, pbs
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 10:32
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Help: Batch file for Parallel Processing ( 2CPU ) SC FLUENT 1 July 15, 2003 22:34
