Hossein Noorsalehi
Rep Power: 0 ![]() |
Hi All,
I have tried to simulate an inviscid supersonic diffuser in Fluent. The inlet boundary conditions are: mach number=3 , Total Pressure is 70000 pa & Total Temperature=300 K. I expect to have a normal shock in the throat or in the beginning of the diverging zone of the diffuser. Therefore the outlet flow regime must be subsonic. As an initial solution, I have put “outlet vent” boundary condition at the outlet with the coefficient of 0.9. The solution has converged and the normal shock has been stabilized in the diverging zone of the diffuser. At the following of the run, when I change the outlet condition to “pressure-outlet”, the converging trend of the solution will not continue. I have tested this procedure with various back pressures at the outlet, but results are the same as above. Would you please help me solving this problem? |
#2 | |
majid
Rep Power: 10 ![]() |
i have same problem |
inviscid flow, normal shock, supersonic diffuser |
Simulating a Supersonic Diffuser | noorsalehi | CFX | 2 | November 23, 2022 13:32 |
[How to obtain supersonic flow inside a supersonic wind tunnel ?] | yx213 | Siemens | 1 | September 17, 2014 13:52 |
Need help defining a momentum source for a diffuser inlet | serezhkin | CFX | 1 | April 2, 2013 12:20 |
Probelm with supersonic exhaust to ambient | newj | CFX | 2 | August 9, 2012 18:01 |
Simulating a Supersonic Diffuser-Need Help | Dileep | Main CFD Forum | 1 | April 18, 2002 06:25 |
