problem in using previous solved data for new mesh |
December 20, 2014, 04:41 |
mehrzad
Rep Power: 15 |
Hello dear friend at cfd-online
I'm working an a ventilation case with fluent and want to investigate mesh independence for my case. first i generate a mesh with adequate frid for my case then solve it with fluent. in next step i generate a finer mesh and using previous solved data for initial solution of finer mesh with two methods provided by fluent 1-interpolation. 2-replacing mesh. but as you know the SIMPLE/C algorithm ruin the velocity field to obtain new solution. is there any way to use previous solution without having this problem? |
cfd, fluent, simple, simplec |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
[GAMBIT] SOFC crossflow mesh possible problem??? | epc1 | ANSYS Meshing & Geometry | 1 | February 4, 2013 01:57 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
