In fluent post processing, difference between, x velocity and axial velocity?
Old   December 18, 2014, 12:12
Default In fluent post processing, difference between, x velocity and axial velocity?
padhu
padmanathan is on a distinguished road
hi all,
In case of simple 3D flow through pipe problem, In Fluent post processing i found the velocity output can be plotted as x, y, z velocity or axial, radial, tangential velocity. the inputs are given as pressure inlet with axial component and tangential velocity (local cylindrical swirl). which system of output i should choose for postprocessing? Cartesian or cylindrical?
padmanathan is offline   Reply With Quote
Old   December 19, 2014, 14:58
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
whichever you prefer
edoan is offline   Reply With Quote
Old   December 20, 2014, 00:42
padhu
in that case, how 'x velocity' and 'axial velocity' outputs are different?
Old   December 20, 2014, 16:13
edoan's Avatar
Ethan Doan
they should only be different if the x direction is not aligned with the axial direction of your pipe
Fluent Axial Velocity Definition zoeburton1987 FLUENT 0 June 7, 2012 10:34
how to plot out circumferentially mass averaged axial velocity in a rotor? wildli FLUENT 0 July 17, 2010 16:54
Axial velocity problem in Fluent clueless FLUENT 1 May 15, 2009 16:06
Axial, Radial, Tangental velocity in FLUENT post Barri FLUENT 2 March 6, 2008 21:29
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
