Laminar flow in a circular duct with a constant heat flux |
December 16, 2014, 04:46 |
Juan Ignacio
Dear friends
I am trying to simulate a circular duct with a constant heat flux using Fluent. I have modelled my case in a 2D case. I have computed the results but I am not able to obtain changes of temperature in all the domain. I just obtain temperature changes in the zone close to the walls (I enclose an image as example). I am not sure which is the problem because I believe I should obtain different temperature in my domain Thank you |
How to set a initial temperature and constant heat flux at same BC's?? | Jane | FLUENT | 4 | October 25, 2015 13:01 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 06:46 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
BC for constant heat flux | saidi | Main CFD Forum | 2 | July 17, 1998 16:02 |
