Fluent running GPGPU throws up divergence error but not in parallel without GPGPU
Old   December 16, 2014, 03:57
Default Fluent running GPGPU throws up divergence error but not in parallel without GPGPU
rsdsaurav is on a distinguished road
Send a message via Skype™ to rsdsaurav
I have been using Ansys Fluent 15.0.7 with GPGPU(K20Teslaa Card). Unfortunately whenever I enable GPGPU it is throwing up divergence which is not the case for running parallel sans the GPGPU. My question is it due to GPGPU that divergence is happening due to auto partitioing the mesh? Or is there any other things that I need to do to remove this divergence error. I generally run Fluent in (Parallel-6, GPU-1) mode.
Any help to my problem will be highly appreciated...
Thanks in advance........
rsdsaurav is offline   Reply With Quote
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 06:07
running a journal file in Parallel FLUENT novice FLUENT 0 June 15, 2010 05:19
Parallel speedup Fluent Gigabit Ethernet Myrinet etc tehache OpenFOAM Installation 5 September 7, 2009 06:51
