How to create hydrostatic pressure in the fluent |
December 14, 2014, 10:59 |
Ebrahim
Rep Power: 12 |
Dear all
How can I create the hydrostatic pressure in the fluent? for example imagine a pool is filled with water at the beginning(t =0) therefore the water must have hydrostatic pressure in the pool. then another fluid is entered to the bottom of pool under pressure via a pipe. how can I create the hydrostatic pressure of water thank you |
December 14, 2014, 17:40 |
Lucky
Rep Power: 66 |
enable gravity?
December 15, 2014, 09:41 |
Ebrahim
Rep Power: 12 |
yes lucktarn, I select the water as primary phase and enable the gravity. but hte hydrostatic pressure of water doesn't create!
December 15, 2014, 21:42 |
François Grégoire
Rep Power: 17 |
It's because when you enable gravity the pressure is redefined as in equation (7-54) here: https://www.sharcnet.ca/Software/Flu...et_hydrostatic
What you're plotting as static pressure is now . If you want to visualize the hydrostatic head, you can quickly define a Custom Field Function that computes , or just . |
December 16, 2014, 16:05 |
Rick
Rep Power: 27 |
I usually set operating density to 0 to get hydrostatic pressure (and enable gravity).
Google is your friend and the same for the search button! |
December 17, 2014, 11:49 |
Ebrahim
Rep Power: 12 |
can I write an UDF for hydrostatic pressure and apply it to the pressure outlet boundaries to create hydrostatic pressure?
December 17, 2014, 12:37 |
Lucky
Rep Power: 66 |
I think the custom field function is easiest to implement.
December 21, 2014, 10:51 |
Ebrahim
Rep Power: 12 |
Dear Luckytran and ghost 82
If I want that at t=0 which there is only water (density =1000) in the whole domain with its hydrostatic pressure and after that another fluid with density 5 is about to enter the domain, I should set the operating density to zero as well ? |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 03:07 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 15:32 |
vof + hydrostatic pressure | ariorus | FLUENT | 0 | August 7, 2009 11:57 |
