Creating an ISOSURFACE
Old   December 9, 2014, 13:06
Question Creating an ISOSURFACE
Feital
feital is on a distinguished road
I'm trying to calcule by 2 ways (in a plane and in a volume) the average density of a mixture (two fluids) in a cylinder (height = 20 meters and radius = 0,5 meters, which is divided (t = 0 seconds) in two parts). The method is VOF (momentum Power-Law).
The non-newtonian fluid (carbopol), which is the heaviest fluid of the mixture, is initially (t=0) located above the newtonian fluid and occupies the superior half of the cylinder.
The first way is the calculation of the average density on the top of the cylinder (z = 20 meters).
To do that, I created a plane parallel to the top. Then, I create a surface monitor (Report Type - Area-Weighted Average) which monitors the variation of the average density with time (seconds).
The problem is the second way! I have to calcule the average density of the mixture in a small superior region
(I mean, between z = 18 meters and z = 20 meters, for example). Then, I have to create a surface monitor to get the results.
I don't know how to do the first step of this way
(create a Isosurface? But how can I especify the region between z = 18 and z =20 ???).
Just to clarify, I'm trying to calcule the variation of this average density with time (in a plane and in a VOLUME)
I aprecciate any attempt to help.
feital is offline   Reply With Quote
isosurface, vof model
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
creating isosurface using journal file dsanthosh2 FLUENT 2 June 7, 2012 04:09
isosurface in CFD-Post for transient rotor-stator simulations blacksoil2012 CFX 1 May 29, 2012 20:07
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
