December 5, 2014, 22:00 |
Comsol Magnetic field data to Fluent MHD
Dinushke
Rep Power: 13 |
Does anyone know how to exactly transfer magnetic field data to the external magnetic field option in the fluent MHD module. From what I see the external mag. field data format in the fluent mhd is quite strange (see attachment). Thanks, Dean |
December 17, 2018, 05:32 |
Eduard
Rep Power: 8 |
For someone, this topic remains relevant.
Can anyone explain the structure of the file that dean993 attached? What does "data point" mean in the MHD fluent manual? Last edited by eduardvinter; December 17, 2018 at 06:52. |
December 17, 2018, 08:54 |
Lucky
Rep Power: 66 |
You just provide a big giant list in the order given
nX = number of x coordinates nY = number y coordinates nZ = number of zcoordinates X1 thru Xn, listall the x coordinates up to nX in number Y1 thru Yn, list all the y coordinates up to nY in number Z1 thru Zn, list all the z coordinates up to nZ in number nAc freq BXre means real part of Bfield in X-direction, BXim means imaginary part of Bfield in Y-direction |
December 17, 2018, 09:28 |
#4 | |
Eduard
Rep Power: 8 |
This part of the file is clear.
I encountered a misunderstanding of the term "data point" in the manual. Information from the Appendix C of MHD module manual: Quote:
For instance, I have an alternating magnetic field calculated in ANSYS APDL. I can write APDL macro for extracting magnetic field induction from each element, but I have to extract this magnetic field induction from each data point. What is it? Thanks |
December 17, 2018, 13:31 |
Lucky
Rep Power: 66 |
The meaning of external is that it comes from some black box without any meaning. You have fields at x,y,z. Just list them. It doesn't matter to the interpreter whether they come from faces/cells/nodes.
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
high continuity Fluent modeling ABL with WRF/CALMET data | xitao21 | FLUENT | 1 | May 2, 2019 11:20 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
computational MHD flows, boundary conditions | packer | Main CFD Forum | 0 | March 21, 2006 04:35 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
