absorption in pipe: transient problem, result seems not take time into account
Old   December 4, 2014, 09:00
Default absorption in pipe: transient problem, result seems not take time into account
Juun
Juun is on a distinguished road
Hi everyone, I am doing a simulation about absorption in a pipe.
some background
Mixture gas (A B C) flow in a pipe, gas A is absorbed on the inside wall.
The inlet conditions are constant (u, t, gas mixture fraction ect…) from 0s-500s, after that temperature and mixture will change. Since gas A is absorbed into the wall, the outlet gas A should remain at 0 for a period at the beginning, then raise to a level that same as inlet (as wall surface cannot take anymore).
Problem
I use transient to simulate this, the result is odd. The trend of gas A level at outlet is correct, but it doesn’t go according to time, but the number of iteration.
For example, gas A at outlet reach 300ppm when the solver run about 2000 iterations, no matter what time step size is used
That means
if time step size is 0.1s, 20 itr/time_step, outlet gas A get to 300ppm in 10s;
if it is 0.5s, 20 itr/time_step, it reaches 300ppm about 50s
if use 0.05s, 20 itr/time_step, it only takes 5s to reach 300ppm
And in fact, if I used 1s on time step size, the result is close to the experiment (yes, by luck), reach 300ppm in 100 second.
It seems like it has nothing to do with time here, but only the total number of the iterations.
Anyone has idea what goes wrong here?
Juun is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Problem (Overflow error + Broken Pipe error?) when Activating Transient Results armlic CFX 0 July 11, 2014 10:50
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
