boundary condition rotating domain
Old   December 2, 2014, 05:20
Default boundary condition rotating domain
Ema40 is on a distinguished road
Hi everybody.
I am simulating a rotating domain of a water wheel. In the lateral surfaces of the rotating domain, which are in contact with the external open ambient, I have used pressure outlet=gauge pressure =0. The operative pressure is 101300 Pa.
It is correct?
I see that inside the rotating domain, the air flows at 40 m/s, which is totally wrong and I can't understand why. If I use symmetry instead pressure outlet this bad result doesn't appear, but, since there is not contact with the open ambient, the inside pressure becomes wrong.
Anyone can help me?
Thank you
Ema40 is offline   Reply With Quote
pressure outlet, rotating domain, symmetry, turbine
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
[GAMBIT] periodic boundary condition for a rectangular duct domain Das ANSYS Meshing & Geometry 26 June 5, 2013 08:48
Domain Boundary Condition sunilpatil CFX 1 March 1, 2013 20:49
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
