Moment-torque coefficient monitoring
Old   November 26, 2014, 06:53
Default Moment-torque coefficient monitoring
Ema40 is on a distinguished road
Hi everybody. I am simulating a turbine and I want to monitor the Cm during the time, but the output written file contains only the Cm in the last step and I don't know why. It is the first time that this problem occurs for me.
I have done this: In solution option-Monitor-Moment-Click on "Write"-Give the file output name-save output parameter-
Thanks
Ema40 is offline   Reply With Quote
moment, rotating domain, torque coefficient, turbine
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
calculate pitching moment coefficient jyh3134 FLUENT 0 January 30, 2013 11:40
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:51
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
