Solution appears to be diverging.
Old   November 24, 2014, 04:05
Question Solution appears to be diverging.
Sumayyah
mia_axt88 is on a distinguished road
I just ran a simple 2d airfoil solution on 0 degrees angle of attack. While Calculating solution the graph seems to keep diverging however no error messages are displayed and no solution appears either.
Assuming that my 4-domain mesh was correct (created in Workbench, on a NACA 4 series custom airfoil, namely NACA 2205), can anyone tell me what is wrong with my Case settings and/or Solution settings??
I tried initializing by both hybrid and standard initialization methods. the graph still appears to be continuously diverging.
For the problem statement of
10 m/s freestream velocity
101325 Pa atmospheric pressure
1.4607e-05 m2/s kinematic viscosity
288.16 K temperature
1.225 kg/m3 density:
Solver: Pressure-based (since velocity is very less)
Model: viscous-Inviscid, Energy-Off
Material: Fluid-air --> constant --> 1.225
operating Condition: 101,325 Pa
Boundary Conditions:
Regions far ahead and above of airfoil (also some area far above but behind airfoil) assigned as Velocity-inlet with component x=10 m/s, y=0 m/s
Boundary far behind trailing edge, perpendicular to tail of airfoil assigned Pressure Outlet
Airfoil assigned as Wall
Reference Values: computed from Inlet (the Boundary ahead of Airfoil and above)
Solution Methods
Spatial Discretization--> Pressure: PRESTO!
Spatial Discretization--> Momentum: Second Order Upwind
I chose simple Cl monitor along with residuals. with both methods of initialization at a time. solution keeps diverging but shows no error, just stops after the given iterations.
Can someone help??
mia_axt88 is offline   Reply With Quote
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 172 April 13, 2023 01:42
Asymmetrical solution using RANS Marli FLUENT 2 January 9, 2015 10:26
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
