Viscous coupling - two rotating disks
Old   November 24, 2014, 03:46
Default Viscous coupling - two rotating disks
AH
visitor is on a distinguished road
Dear sir/madam:
Trying to simulate viscous coupling, basically two disks rotating at different speeds with disk planes facing each other and separated by eg 1 mm.
Selected Silicon fluid and run the analysis, no impact seen. Should see reaction forces due to the different rotating disk speeds.
Q1. There are so many Silicon fluids in Fluent material library, is Silicon fluid the right choice?
Q2. Should I select the power law from the material library, and what figures shall I enter?
Q3. Any other specific settings, please?
Thanks in advance.
visitor is offline   Reply With Quote
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 11:27
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Flow between rotating disks behrang2009 FLUENT 0 March 10, 2012 17:47
axisymmetric model of two rotating disks cavity liaolingling FLUENT 0 April 27, 2005 05:24
Coupling of inviscid and viscous flows coulibaly Main CFD Forum 0 August 26, 2003 14:28
