Solution will not converge?
Old   November 18, 2014, 16:47
Default Solution will not converge?
Mark
woodmark75 is on a distinguished road
I'm trying to simulate a wind tunnel test. The Fluent model has a fluid domain of 460 x 460 x 1220 mm, & at the center is a wing 'projected span' = 200mm, 'center chord' = 81.82mm.
The educational version I'm using is limited to 512,000 cells. I've tried to use a fine mesh with 'inflation' layer on the wing. Slightly bigger mesh in a 'sphere of influence' around wing. Again a slightly bigger mesh for the rest of the 'fluid domain'.
I'm using a coupled 'Pressure/Velocity', 1st order model, but can not get convergence. What should I do to try and get it to converge?
Just incase, I've attached the files below:
wbpj: https://app.box.com/s/vmiug2jscpole18zgod4
associated: https://app.box.com/s/vvezn5irwk2l9f5ga9is
woodmark75 is offline   Reply With Quote
convergence problems, fluent
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
simple algorithm, converge of solution bbasal Main CFD Forum 0 February 13, 2010 03:58
Solution Does Not Converge Rif Main CFD Forum 3 March 7, 2008 06:33
My Solution wont Converge!!! Chris FLUENT 6 April 16, 2005 19:57
what to do when solution doesn't converge? Jenny CFX 5 January 28, 2004 05:00
