flow in a nozzle with two narrowed cross section
Old   November 17, 2014, 10:00
Default flow in a nozzle with two narrowed cross section
N. Wei
whitecat is on a distinguished road
Hi, all,
I am trying to run Fluent v15 to simulate the flow through a nozzle with two narrowed cross section.
I use the velocity-inlet condition at the inlet and the pressure-outlet condition at the outlet.
With the pressure-based solve I can get a converged solution.
While the flow at the first cross section remains subsonic, arrives the Mach number at the second cross section a value of about 1.3.
If the density-based solver is selected, I have problem to judge the convergence.
The globally scaled residual of the continuity equation stays at 0.01 after 10000 steps.
But if I check the locally scaled residual of the continuity equation, the value is below 1.0e-9.
My question is: is the continuity equation converged or not?
Any help would be greatly appreciated.
Ning
whitecat is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
simulation of cross flow cylinder ravigdch Main CFD Forum 0 April 23, 2014 11:13
Flow in duct with a heat transfer section. marauder FLUENT 6 March 5, 2014 13:42
Nozzle Flow - Divergence Problem Ijaz FLUENT 9 January 11, 2014 05:36
Subsonic flow in a supsersonic nozzle Laplacien FLUENT 0 April 6, 2006 04:27
