Solution not converged for supercritical annular flow
Old   November 14, 2014, 03:29
Default Solution not converged for supercritical annular flow
Kiran Saikia
K.Saikia is on a distinguished road
I am trying to simulate heat transfer to supercritical pressure water flowing through an annulus with inner wall heated and outer wall adiabatic, using ANSYS FLUENT 14. I am using realizable k-e turbulence model with enhanced wall treatment and SIMPLEC algorithm for pressure velocity coupling. The flow condition is as follows:
mass flux at inlet: 2200 kg/m2.sec
heat flux at inner wall: 2410 kw/m2
operating pressure: 23.5 MPa
inner dia 8mm, outer dia. 10 mm
I am able to run the simulation but it is not getting conversed. The continuity is not conversed.
Can anyone please help me to solve this problem???
K.Saikia is offline   Reply With Quote
annular flow, fluent 14.0, supercritical water
solution is converged but a problem flow_CH FLUENT 9 June 2, 2020 10:34
Eulerian Granular flow:receive reverse flow and solution isn't converge bahman FLUENT 1 January 2, 2014 12:53
Annular Flow Model for tw-phase flow. applemango FLUENT 0 September 9, 2010 05:44
initialize flow field with steady state solution holg FLUENT 0 July 13, 2009 18:10
how to deal with annular flow in fluent yong FLUENT 1 January 4, 2008 08:35
