Monitoring velocity of a turning wheel on screen - Fluent |
November 12, 2014, 08:52 |
AH
Dear sirs/madams:
Tried several ways; Through surface ; point, then plane then zone. And through the solver monitor created surface monitor and volume monitor, then from volume, max, velocity then tangential velocity. Nothing can be seen with a speed on screen. Need to see a velocity curve plotted against time steps, for a rotating wheel. Thanks in advance. |
A Question About Setting Whole Velocity Field Using "Proflie" in FLUENT | adsl17754 | FLUENT | 5 | July 31, 2018 05:29 |
Monitoring Volume Average of Liquid Velocity Magnitude in a Bubble Column / Airlift | kevinlipps | OpenFOAM Post-Processing | 4 | May 19, 2016 06:59 |
FLUENT not even close to experiment | khoopes | FLUENT | 0 | March 9, 2012 13:55 |
Modeling Unsteady velocity in Fluent | Vidya Raja | Main CFD Forum | 0 | November 11, 2005 17:11 |
Non-uniform inlet velocity application in Fluent | ghlee | Main CFD Forum | 2 | August 11, 1999 22:32 |
