velocity contours
Old   November 11, 2014, 20:40
Default velocity contours
hwet is on a distinguished road
The left picture is of velocity magnitude and the right one of tangential velocity in a cyclone body, i expect the tangential velocity contours to be the same as the velocity magnitude ones with just being a little lower in value but they appear to be different includin negative values as well, although the flow is all in one direction (clockwise). Can anyone tell where i am going wrong? maybe something to do with orientation?
hwet is offline   Reply With Quote
Old   February 22, 2015, 08:58
aah
sutiut is on a distinguished road
Hello Dear,
I have the same problem as you. I can not generate radial & tangentical velocity contours, right.
Could you?
please explain your method.
thanks,
Amir
sutiut is offline   Reply With Quote
Old   February 22, 2015, 19:02
i just plotted the vel mag, which seem right, the components i could not figure out, if you find a way let me know as well
Old   February 23, 2015, 09:41
Paritosh Vasava
vasava will become famous soon enough
Do you have any rotating frame of reference?
vasava is offline   Reply With Quote
Old   February 23, 2015, 10:43
What do you mean by that? I tried to figure this rotating frame's meaning out but gave up... could you elaborate, and you can see what i mean from my pictures above...thanks
Old   February 23, 2015, 11:23
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Did you set correctly the rotation axis origin and direction in fluid panel?
Vasava was asking if you enabled the reference frame calculation in your simulation: if you don't know what it is, probably you didn't enable it.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   February 23, 2015, 18:37
Actually I did, and the contours above are those after setting the rotation axis, actually many people said that tangential velocity should be negative on one side and positive on the other but i kept on thinking they did not quite understand what i meant. do you guys personally think that the above contours are fine? or do you agree that the tangential velocity contours should be like vel magniude contours (positive)
Old   February 23, 2015, 19:16
ghost82's Avatar
Rick
Sorry to be repetitive, but did you check if the rotation axis is coincident with the "vertical axis" of your cyclone? If the cyclone is centered in respect to the origin rotation axis is y or -y.
Moreover if you have multiple fluid zones make sure you setup the correct zone in the reference panel.
Old   February 23, 2015, 19:25
Thanks, I am going to do this again and get back to you. but also you do believe that the tangential vel contours are wrong and shouldnt be negative? I have seen many published research papers which plot them both positive and negative and i always suspect they are wrong...
Old   February 24, 2015, 03:31
Paritosh Vasava
I think ghost82 has given you all the hints you need. When you use reference frame the velocity and tangential velocity appear to be identical except that the magnitude are in inverse (Please remember that the absolute magnitude may not be the same). This is due to the fact the tangential velocity is relative to the axis of the rotating frame of reference. This is why if you plot tangential and relative tangential velocities they should be exactly the same.
Old   February 24, 2015, 04:56
ghost82's Avatar
Rick
Yes, your tangential velocity contour is wrong: do not confuse x or z velocity (in your case) with tangential velocity.
See definition here of tangential velocity and how fluent handles it:
http://aerojet.engr.ucdavis.edu/flue...g/node1217.htm
If you look at the cylinder, taking into account the position of rotation axis the arrow indicating the tangential velocity has a positive sign (counterclockwise); opposite direction (clockwise) has negative sign.
If you define the axis with direction opposite to the axis indicated in that figure, the indicated arrow for tangential velocity will have negative sign (clockwise).
See some pictures I'm attaching for x,y and tangential velocity.
Daniele
Old   February 24, 2015, 05:18
ghost82's Avatar
Rick
I see that you used cfd-post for post processing; by default tangential velocity is not available, so first you need to set rotation axis in cfd-post (define global rotation axis) and calculate velocity components (calculate velocity components), in "turbo" tab.
Then you can choose to plot the "Circumferential velocity" which is tangential velocity.
Otherwise plot your contours directly in fluent, by choosing tangential velocity.
Streamlines colored by velocity contours Andrea1984 Tecplot 3 December 30, 2022 09:20
LES and TKE calculations MST Main CFD Forum 3 May 30, 2016 07:26
Contours of velocity in pump aja1345 FLUENT 2 February 18, 2014 02:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
