Flow in Closed Loop
Old   November 11, 2014, 13:26
Default Flow in Closed Loop
Vaibhav
vsgavhale is on a distinguished road
I have to simulate flow in a closed loop. I have a closed loop filled with liquid CO2 (Operating Pressure and Temperature Specified, Single Phase). Considering loop to be divided in 4 parts namely, upper,lower,right and left side. Right & left sides are perfectly insulated while the the upper and lower parts are at two different temperatures (Wall Temperature at respective parts being constant throughout).
I had specified the above conditions and used PISO Scheme but not getting the correct results.
Please help me out. Thanks in advance.
vsgavhale is offline   Reply With Quote
Old   July 11, 2017, 07:49
Meghana
Meghana is on a distinguished road
hi,
i am trying to do the same. Can you help me with the boundary conditions that need to be specified?
Meghana is offline   Reply With Quote
closed loop, fluent 15
Modeling Flow through Closed Loop System CFDisFUN FLUENT 5 June 25, 2015 16:54
Modeling a close loop inner flow ?! enjoykevin CFX 2 April 19, 2013 19:39
Closed loop pipe flow maddalena OpenFOAM Running, Solving & CFD 34 August 16, 2011 12:46
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Flow in a Closed Loop John Collins Main CFD Forum 2 February 27, 2003 11:26
