fluent batch submission
Old   November 10, 2014, 21:12
Default fluent batch submission
hwet is on a distinguished road
Hi, i set up a case with first order and submit the job to a cluster, after the results i change it to second order, i cant get fluent to solve with the second order schemes by continuing on the data obtained from before, any ideas what needs to be done, for example how to change the journal file so the solution for second order continues from the data obtained from the first simulation?. ]
thanks
hwet is offline   Reply With Quote
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
Fluent 15.0 Parallel and Batch Processing on a Supercomputer n_bowen FLUENT 0 August 26, 2014 14:46
Fluent Batch Mode - TUI Diane FLUENT 13 June 3, 2014 06:11
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
problem with fluent in batch mode Pat FLUENT 2 February 13, 2003 14:14
