my case works fine with FLUENT 14.0 but gives error with FLUENT 15.0 |
November 10, 2014, 10:19 |
#1 | ||
Rep Power: 12 |
Hi everybody
Here is a short description of my case: -geometry: 3D, spherical cavity -unsteady -two phase flow with free surface (using VOF) -laminar The spherical cavity rotates with a time varying angular velocity. This motion is imposed, using a UDF and dynamic mesh technique. My case works fine with FLUENT 14.0 in both serial and parallel modes. Now I'm forced to use FLUENT 15.0. It gives this error message in serial mode: Quote:
and this error message in parallel mode: Quote:
And this is my UDF, which I use for dynamic mesh: PHP Code:
I will appreciate any help Thanks |
December 19, 2014, 07:00 |
Wei Yanji
Hi ayousefi,
Have you solved your problem? I met the same error using VOF+dynamic mesh(cutcell). But I did not meet such problem with dynamic layering remeshing with the same UDF. I guess the error comes from the remeshing method. I appreciate if you can share your experience. Thank you |
error, fluent, udf, vof |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
fluent case n data files not exporting to tecplot | krishna | FLUENT | 2 | February 17, 2007 23:24 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Fluent case file into Gambit | Eric R. | FLUENT | 7 | July 17, 2002 14:11 |
