the problem that gradually change of temperature contour in coal gasification
Old   November 10, 2014, 03:41
Default the problem that gradually change of temperature contour in coal gasification
hana
bluenail is on a distinguished road
First of all,
sorry for poor writing
Now I am studying coal gasification.
it has similar shape like this photo
(I can't upload my own figure bcz of policy)
inlet port has a angle to make a swirl
Basic method of this calculation is like this
1. Pressure based solver
2. steady sate
3. k-e RNG turbulence model
4. Almost discrete scheme is quick
(1st, 2st order also have a good solution, but temperature profile is bad ^^)
5. adapt stochastic tracking for the simulation
Main problem:
after residual stable, temperature contour gradually changed ㅜㅡ
hahahahahahahahahahahaha
Residual is ok, and temperature of each space is ok
But figure of temperature make me crazy
in MIT paper
[Multiphysics Simulations of Entrained Flow Gasification. Part II:
Constructing and Validating the Overall Model]
they say like this
A possible explanation for this observation is that it becomes
increasingly difficult to find a steady-state solution to the
inherently transient problem of turbulent two-phase reacting
flows in gasifiers as increasingly finer structures are captured
though mesh refinement.
-> mesh number cause problem for solution
But in my case, mesh number is little bit small,
almost under 200,000 mesh
I thought basic cause of this simulation is
unstable of turbulence....
bcz k, e value of turbulence defined the reaction rate
But how could I stable turbulent calculation ????
i tried this method
http://www.cfd-online.com/Forums/flu...tml#post122278
But it fail too
hahaha
is there anyone know how to stabilize the turbulence calculation during coal combusiton????
bluenail is offline   Reply With Quote
To change temperature in mass flow inlet boundary condition per iteration ajinkya201991 FLUENT 1 July 11, 2014 12:29
temperature contour - heat exchanger chinna FLUENT 0 June 3, 2013 06:25
Change Temperature boundary by a solver (rhoPimpleFoam) fredo490 OpenFOAM Programming & Development 7 May 15, 2013 12:11
Contour Problem in Interface Boundary inra FLUENT 1 May 29, 2010 06:22
