November 8, 2014, 03:44 |
Pressure drop VS time on transient problem
ahmad
Rep Power: 14 |
Hello every one I am going to simulate transient problem. I want to know how can i calculate Pressure drop VS time on transient problem by using Fluent ? ( I have rectangular channel with transient problem of water flow with constant heat )
November 8, 2014, 12:36 |
Gbenga
Rep Power: 12 |
Go to surface monitor, from the Report type > select area- weighted average, from Field variable - static pressure and surfaces > select inlet. I assume you use pressure base solver with 0 pressure at the outlet, the the pressure drop will be In;et minus Outlet, which is essentially inlet pressure. Then, X-axis > select flow time and Get Data Every > select time step
November 10, 2014, 04:41 |
#3 | |
ahmad
Rep Power: 14 |
June 10, 2020, 15:07 |
Hannah Northrup
Rep Power: 6 |
Hi I am trying to do the same thing as far as calculating pressure drop vs time and am having trouble. Do you know if this is done the same way in Fluent 2019 R3? Also can this be done after a simulation is already run or does it need to be set up prior?
Thanks! |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 03:34 |
a problem in calculating pressure drop in Fluent? | yu chun | FLUENT | 1 | May 18, 2004 04:40 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
