Solution not converging
Old   November 7, 2014, 05:24
Default Solution not converging
WEI-BO
BECK DING is on a distinguished road
I'm trying to run a simulation of steady, laminar flow of water which comes into a rectangular microchannel inlet (1.8mm width and 0.4mm height ),via eleven smaller rectangular channels (0.2mm width and 0.4mm height) and exist via a rectangular outlet (1.8mm width and 0.4mm height ).
For this purpose I have created a 3 dimensional mesh in Ansys Meshing and solved it in FLUENT 15. When it iterates for lower velocities such as less than 1.0 m/s ,the solution converges but it does not converge for higher velocities just like 2.0 m/s.
When I try to switch the inlet to “pressure inlet”, and pressure drop between inlet and outlet is 50 kPa. The average fluid velocity in #5 channel is equal to 5m/s. The Reynolds number base on the average velocity and channel is 1333 so it’s reasonable for me to use laminar model. But I was using fully turbulent models such as k-e models the convergence is good except for the laminar model
Somebody give me some advice please, I'm really not sure what to do next.
BECK DING is offline   Reply With Quote
laminar flow, microchannels, steady
Trying to perform test validity of Fluent with simulation of 2D airfoil didiean FLUENT 39 December 5, 2015 14:31
Solution not converging dhands FLUENT 0 April 25, 2014 15:04
SU2_EDU version solution not converging.. akanoria SU2 2 March 4, 2014 06:49
My steady state solution converges for a while but stops converging C.C Fluent UDF and Scheme Programming 0 October 9, 2013 12:11
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 14:37
