convergence problem in 2D steady supersonic flow
Old   November 4, 2014, 08:10
Default convergence problem in 2D steady supersonic flow
mohamed mohsen
sehs15 is on a distinguished road
Hello Guys ..
I'm simulating a flow over a 2D supersonic airfoil with fluent, steady state, density based solver, structured quad cells with yplus around 2 and SA turbulence model, boundaries are velocity inlet and pressure outlet
the problem is the solution doesn't converge such that the residuals are fixed at certain values and the mass flow rate and pressures at certain locations keep oscillating periodically with large amplitude.
i tried to reduce the CFL up to 0.01! oscillations exist with less amplitude.
Can anybody help with this problem im stuck!
sehs15 is offline   Reply With Quote
Old   November 5, 2014, 07:47
AAA
cfdkid is on a distinguished road
Hello
As you know, there are various reasons why the solution doesn't converge.
I guess the domain of your solution is too small.
How big is the size of domain?
At least the domain behind airfoil must be approximately 10~15 times the chord length.
cfdkid is offline   Reply With Quote
Old   November 5, 2014, 08:47
mohamed mohsen
yeah the domain behind the airfoil is about 10 times the chord .. i tried pressure inlet boundary and its much much more better than velocity inlet with little oscillations ,, i will try to reduce the CFL with the pressure boundary
Old   November 5, 2014, 19:58
AAA
I found same problem with your problem.
Please look at this thread.
http://www.cfd-online.com/Forums/fluent/112445-pressure-far-field-vs-velocity-inlet-pressure-outlet.html
Originally Posted by Santos-Dumont View Post
It is pretty straightforward, you can easily find some things about that on the Fluent Theory Guide. Anyway the thing is that VelocityInlet/PressureOutlet are only used for incompressible cases only (velocity under Mach 0.3)
If you are compressible (this is usually set up by setting your material density to Ideal Gas and Viscosity to Sutherland) you shall use Pressure Far Field. You can use your entire boundary (i.e inlet, outlet and sides) and set it up as one single boundary in your meshing software, that saves time while setting up in Fluent.
So velocity inlet for incompressible, and pressure FF for compressible.
Old   November 6, 2014, 08:06
mohamed mohsen
thank you bro ,, but it seems like pressure boundaries also have fluctuations , i will try to extend the domain much more ans see
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Modeling unsteady multiphase flow in porous media - convergence problem Vaibhav Kumar Main CFD Forum 1 July 22, 2012 05:32
Convergence Problem with body force driven flow Jinfeng FLUENT 1 December 9, 2009 04:54
CFD-ACE compressible flow convergence problem DelphineL Main CFD Forum 1 October 21, 2009 06:50
initialization of flow field to enhance convergence rate to steady state vfico Main CFD Forum 0 September 9, 2009 12:23
