Double Pipe-Counter flow-3 pass-Ammonia LVHE
Old   October 30, 2014, 12:20
Exclamation Double Pipe-Counter flow-3 pass-Ammonia LVHE
Manu Poolakkal
Manu Poolakkal is on a distinguished road
I am an M.tech student. To complete my project I have to evaluate a double pipe counter flow ammonia liquid vapor heat exchanger using ANSYS Fluent. I have done the modeling. I am not a pro in Fluent. In my try, I got result which showed no heat transfer (something went wrong and I don't know what it was). Somebody please give the instructions to solve it in Fluent.
Thank You.
Manu Poolakkal is offline   Reply With Quote
Old   November 1, 2014, 11:15
amin.z's Avatar
Amin
amin.z is on a distinguished road
Thank You.
hey
are you sure the boundary condition between fluids is correct?
Can you attach a pic and explain your boundary condition?
amin.z is offline   Reply With Quote
Old   November 1, 2014, 14:03
Manu Poolakkal
Thank you for your response
I have given all these values and still the problem persist.
the heat transfer is occurring only at the inlet and outlet manifolds and not in the heat exchanger (concentric tube) region.
BCs are
vapor inlet (inner pipe)
velocity= 101.48 m/s (1,0,0)
temp=263.7056 k
pressure= 137890 pa
liquid inlet (outer pipe)
velocity=0.4511 m/s (0,-1,0)
temp=306.2055 k
pressure= 1275530 pa
Material Properties are
ammonia vapor (inner fluid)
density=1.1182 kg/m3
u=.0000089206 pa-s
Cp=4642.4 j/kgk
k=1.5781 w/mk
ammonia liquid (outer fluid)
density=591.4082 kg/m3
u=.0003112017 pa-s
Cp=4790.2 j/kgk
k=1.432 w/mk
Pipe material steel
k=45 w/mk
Old   November 1, 2014, 15:21
amin.z's Avatar
Amin
BCs are
temp=263.7056 k
pressure= 137890 pa
temp=306.2055 k
u=.0000089206 pa-s
Cp=4642.4 j/kgk
k=1.5781 w/mk
u=.0003112017 pa-s
Cp=4790.2 j/kgk
k=1.432 w/mk
Pipe material steel
k=45 w/mk
what is the BC between 2 fluid zones? Do you have a wall between them? have the walls between zones "shadow" ?
Old   November 2, 2014, 02:48
Question
Manu Poolakkal
Yes, there is a steel wall (inner pipe) between the two fluid zones and the walls between zones have shadows.I have attached a pic showing my boundary zones. At present I have the boundary conditions only at the inlet and outlets of the liquid and vapor zone (actually I have to find the outlet temperatures of fluids generated by fluent and compare them with my theoretical values). What do you mean by "boundary conditions between the fluid zones". Can we take the average of inlet and outlet temperatures of each fluid zone to get the fluid zone boundary condition?.
Old   November 6, 2014, 05:44
Default double pipe geometry
manish sharma
m7566 is on a distinguished road
sir can u give me a tutorial how to design double pipe heat exchanger in gambit please help me sir i am final year student i have desing project on cfd analysis of double pipe heat exchanger using gambit and fluent
m7566 is offline   Reply With Quote
Old   November 6, 2014, 07:47
Manu Poolakkal
i am not an expert in gambit. why don't you model the object in design modeler?. It doesn't matter which modeler you are using. if you use design modeler, i will help you.
Old   November 6, 2014, 07:49
Manu Poolakkal
sir
i found the error which was in my model. there was an error in creating a hole in the pipe. now everything is cleared. hope u ll help me to rectify my further errors. thank you.
Old   November 6, 2014, 17:46
amin.z's Avatar
Amin
Oh! Sorry friend! I forgot this post!
I'm Happy that your problem solved!
Old   November 7, 2014, 00:03
Manu Poolakkal
its fine sir.
but i am in another trouble. in my heat exchanger, there is phase change occurring at the vapor side. i don't know how to achieve the same in fluent. how to select the appropriate phase change model? is there any good tutorial about phase change?
Old   November 8, 2014, 02:52
amin.z's Avatar
Amin
Hey
Good!
My main skill is in aerodynamics! Not multiphase!
But if you refer to ANSYS fluent tutorial guide ( specially chapters 19,20,21,22,23), maybe helps you!
Old   November 14, 2014, 00:04
Default iteration problem
  #12
Manu Poolakkal
Hey
Good!
i have completed fluent procedure. when i give a small number of iterations the temperature range is fine and almost correct(say 250 to 350 k). but for solution convergence when i give a large number of iteration the temperature widens to an abnormal range(say 250 to 5000k).can u id the reason?
countercurrent flow, counterflow, double pipe, heat exchanger, liquid vapor
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 15:28
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 12:33
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 05:04
