Fluent Cd*A and local time for each iteration print out
Old   October 30, 2014, 10:11
Question Fluent Cd*A and local time for each iteration print out
Benjamin Hogan
benjaminhogan is on a distinguished road
Hi
I am relatively new to all things Fluent, but I was wondering if I could bend the ear of someone with a bit more experience.
I have two questions;
  1. I want my drag monitors in Fluent to output the Cd*A, rather than the Cd. Could this be done by setting the reference area to 1? Are there any unforeseen drawbacks of doing this?
  2. My University's Linux parallel cluster is a bit up and down recently. I was wondering if it is possible for Fluent to print out the local time for each iteration? This would allow me to pin point what time my case failed.
Any help with the matters about would be greatly appreciated.
Ben.
benjaminhogan is offline   Reply With Quote
Old   November 4, 2014, 13:32
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Hi Benjamin,
You are correct. The only drawback is in the quantity itself, CDA has the units of m^-2 and would probably not be acceptable if used in a published paper, but if you want to use it, then your method is fine.
I would be suprised if it was only recently and not always. Clusters are never as easy to work with as anyone wants them to be!
Yep, just put the following line in your journal file somewhere:
/solve/execute-commands/add-edit print-time 1 "iteration" "!date"
This isn't the nicest solution, but it will put out a timestamp after each iteration. It's just using the UNIX date command, there are better platform independent ways of doing this using the scheme "time" command, but I'm not sure of the correct syntax (anyone?)
Stu
stuart23 is offline   Reply With Quote
drag, fluent, local, monitors, time
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
Question on transient simulation in OpenFOAM and FLUENT nicklj OpenFOAM Running, Solving & CFD 4 May 8, 2014 23:30
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Response time of Fluent support Rami FLUENT 8 March 5, 2008 03:00
