Eulerian Wall Film Model with radiation
Old   October 30, 2014, 08:02
Default Eulerian Wall Film Model with radiation
Sercan
wetru is on a distinguished road
Hello
I am trying to simulate the condensation on a headlamp. condensation occurs on inner surface of the lens. I try to use Eulerian Wall Film Model. this model is working good without bulbs ON. But when I gave energy to the bulb which means high radiation, results become unreal. since outer air temp is 23°C, and the bulb gives radiation energy to the lens, I had app. (minus) -250 °C on lens surface which is not realistic. By the way I am using DO radiation model.
In help menu there is an explanation as below.
28.1. Limitations
The following limitations exist for the Eulerian Wall Film model:
  • Available for 3-D geometries only
  • Compatible with stationary walls only
Many models (e.g., VOF multiphase flow or radiation) will not interact correctly with the film model without first modifying the boundary conditions using UDFs.
I wanted help from ANSYS support, but do not receive any feedback yet.
So I would like to ask you if anybody knows such kind of problem, and which kind of UDF needed for solution?
wetru is offline   Reply With Quote
Bai-Gosman droplet impaction model in StarCCM+ crevoise STAR-CCM+ 2 April 25, 2019 09:02
Using radiation model for simulation of flat plate solar collector marjanbn FLUENT 1 February 24, 2017 18:22
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
