Uplus vs Yplus with K-Epsilon Turbulent Model in Fluent
Old   October 29, 2014, 07:43
Default Uplus vs Yplus with K-Epsilon Turbulent Model in Fluent
sandpants is on a distinguished road
I am having extreme difficulty getting this to work. Likely because I have no clue what I am doing.
2D problem.
I am required to compare the law-of-the wall profile to the Uplus v Yplus computed in fluent for a K-Epsilon turbulent flow, kinda like whats shown here http://www.cfd-online.com/Forums/flu...-vs-yplus.html.
Fluent gives Yplus but not Uplus.
I tried defining Uplus as a Custom Field Function. Cannot get it to work - the contour plot gives zero (0) through out the whole fluid domain.
I am expressing Uplus as |V|/Utau, where Utau=sqrt(x-wall-shear/density).
The unnerving part is that Utau is not 0 near the wall(expected) and some distance from it and Velocity is only 0 at the wall (no slip). So why am I getting 0 EVERYWHERE through-out the fluid domain?
I am also having excessively large Yplus values reaching 700. I cannot refer to the source thread, but on these forums I've read that that would be due to high TKE. I have flow an inlet flow velocity of 30m/s and a hydraulic diameter of 0.177m. Re=354000. In the K-E setup I set TKE as 1.42m^2/s^2, but contour plots show TKE upto 40 in some places.
Please advise.
sandpants is offline   Reply With Quote
Old   October 31, 2014, 01:00
Lucky
The yplus value that Fluent gives you is only the yplus of the wall adjacent cell, also sometimes called wall y+. Fluent does not give you y+for any of the interior cells that are not directly adjacent to walls.
Try not to confuse this wall y+ with the canonical y+, which is closely related to the cell Reynolds number.
utau is a surface property whereas u+ and y+ are fields. My guess is you are trying dividing u(x,y,z) by utau which is defined only on the surface. Since utau is not defined on the interior, it it should not report any values there.
Garbage in, Garbage out.
Old   December 17, 2022, 13:08
Default U plus
adam
medguedem is on a distinguished road
good hi
I have same problem how can i draw fluent u+ vs Y+ graph in cfd-post fluent
if you found a solution please send me.
medguedem is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 10:53
Is it possible to model natural convection in a 2D horizontal model in fluent caitoc FLUENT 1 May 5, 2014 14:32
What turbulent flow model choose in Fluent ja.maldonado1187 FLUENT 2 August 11, 2013 07:33
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
