Scramjet Intake Analysis
Old   October 24, 2014, 16:35
Default Scramjet Intake Analysis
Akshay Deshpande
akshaydeshpande is on a distinguished road
Hello everyone,
I am doing a 3d scramjet analysis on ansys fluent but am not obtaining the desired shock pattern after ~12000 iterations. I have used the following conditions:
-Density based solver with density of air mentioned as "ideal gas."
-Energy equation-on; k-omega SST turbulence model.
-The operating pressure is 0 Pa.
-The boundary conditions I have used are:
1. Inlet: Pressure far field - Supersonic gauge pressure: 12350 Pa; M=3.2; Turbulent intensity and viscosity ratio=2%, 10.
2. Top, Bottom: Wall; No-slip conditions.
3. I have not modified the outlet b.c since fluent extrapolates the outlet conditions as the simulation proceeds, from the inlet.
-Solution methods: Implicit Roe-FDS; Discretization: Second order (started initially from first order).
-I have reduced the under relaxation factors initially and went on increasing gradually as the solution started to become stable.
-All residuals: 1e-05; Surface monitor: Mass flow rate at the outlet.
-To capture the shocks, I have followed the method as per the ANSYS tutorial: Grid Adaption using pressure gradient; Coarsen threshold:0.3; Refine threshold:0.7; Max no of Cells:20000.
I have attached the geometry, mesh (with mesh quality histogram) and some of the results (at the mid plane) after the analysis. As observed in the pressure contours (Fig 4), the pressure should gradually increase from the inlet instead of decreasing while in the velocity contours (Fig 3), the velocity should gradually decrease instead of increasing. Also, no oblique shocks are observed.
Please suggest any changes or improvements required.
akshaydeshpande is offline   Reply With Quote
Old   November 18, 2014, 07:32
Default :)`
vineeth tom
vineeth_tom is on a distinguished road
Check with M=7, you'll get it.....and use T=5 % and length ratio...and instead of giving pressure inlet ,outlet,,give pressure far-field for the outlet part as well as you dont need the exit things..try ,you'll get the result..this is because the inlet would slow down m=3.5 to subsonic speeds and ur starting mach no is obviously not 3.5...and what is that pointed extension..not that clear...
vineeth_tom is offline   Reply With Quote
Old   January 21, 2015, 01:20
Akshay Deshpande
Sorry for a belated reply! I discussed this issue with my professors and they told me that my domain definition is incorrect. I have been working on their suggestions and will post as soon as I get the result.
Old   January 21, 2015, 06:17
vineeth tom
i am working on scramjets too........can u help me with 3d meshing prefarably in hypermesh or any other meshing software for the domain if i give u a pic.??Mapped or manual meshing ,,,not adaptive
Old   January 27, 2015, 05:04
Akshay Deshpande
I myself am learning ICEM CFD for structured meshing. But you can send me your domain. I'll try my best.
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
analysis of wall injector based scramjet combustion samironsaikia FLUENT 1 April 18, 2011 01:34
Intake manifold analysis alonzoo STAR-CCM+ 2 July 6, 2010 05:00
Intake manifold analysis mehndan Siemens 3 August 22, 2008 05:24
Intake manifold analysis mehndan Main CFD Forum 6 July 3, 2008 06:28
