Error The mesh file exporter does not support overlapping geometry in Contact Regions |
October 22, 2014, 11:26 |
Rep Power: 11 |
hello,
I am trying to mesh a filter holder. I have three parts, the part for the in flow, the filter (which i created it as a surface so as to later define it as porous jump) and the part for the outflow(the meshing tool recognizes the connections in between these parts). However when I am trying to mesh it I receive the following error from fluent Error:The mesh file exporter does not support overlapping geometry in Contact Regions. Please resolve the issue and try again. I tried to use the match control but it did not work. I have not set the named section in this step since the solver cannot read my meshing.Can it be the problem? Also, it cannot recognize the filter surface as a surface with 2 faces during the geometrical set up. Since I am new in cfd I cannot completely inspect what is going wrong Any recommendations? Thank you very much |
March 11, 2015, 13:47 |
Bojan
Hello
I have similar problem, did you manage to solve this |
March 11, 2015, 14:16 |
Rep Power: 11 |
If you refered to the use of a surface as porus jump, ehat i did is to delete the problematic surface. Thus i have two parts, the upstream and downstream part. Then i create a new part that i assigned the two separate parts as one. So i can define the interferance of those parts as porus jump.
Hope it can help you |
March 11, 2015, 15:27 |
Bojan
Yessss, thank you kind sir
And really fast response |
error, fluent |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
