LES Post Processing (instantaneous contours)
Old   October 21, 2014, 06:44
Unhappy LES Post Processing (instantaneous contours)
Adnan Nweilati
adnan.nweilati is on a distinguished road
Hi all,
I have a solved LES model. But I have to idea how to view an instantaneous contours. (I need to view the contour at specific times).
My time step is 0.001 (s)
Number of time steps = 2500
Max iteration/time step = 80
And I turned ON the Data sampling for time statistics. (which I have no idea what does it do :/)
I feel that I had to add more input in Calculation activities or something but I have no idea what exactly to add/change.
To be honest Im not sure if the results I got is right or not. I attached a screenshot of the results.
Fluent help is absolutely useless.......
Im have being using Fluent for 3 weeks now. So you can say Im really inexperienced in it.
Thanks
adnan.nweilati is offline   Reply With Quote
Old   October 21, 2014, 15:34
Ali
nettpanic is on a distinguished road
For plotting Contours at different time step, I use this method:
Go to calculation activities, then save data files at your desired time step intervals. Finally load the data file for your desired time step and get contours at that time.
nettpanic is offline   Reply With Quote
Old   October 21, 2014, 16:09
Adnan Nweilati
Thank you! This process takes so much memory tho
clueless, contours, fluent, instantaneous, les
Utilities: post average turbulence fields and create turbulence fields for LES Hanzo OpenFOAM Running, Solving & CFD 10 August 18, 2017 19:33
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 07:21
[OpenFOAM] is parallel processing available in parafoam for post processing? sachinlb ParaView 1 August 14, 2012 10:52
LES post processing moun FLUENT 0 April 23, 2005 11:30
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
