Using a function of input parameters as reference value |
October 20, 2014, 10:57 |
Michael Kruger
Rep Power: 12 |
I am optimizing the length of a streamlined body for minimum drag, where the reference value for the drag coefficient is a function of the geometry.
I can express this as a function of different input parameters, and what I need to know is if I can use a function of input parameters as a reference area, as this is what fluent uses to calculate the drag coefficient. Thank you for any help.
------------------------------------------------------- Michael |
March 26, 2022, 06:06 |
Adam
Rep Power: 4 |
Did you find an answer to this lol?
ansys, fluent, optimization, parameters |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
problem with turbulence models after compilation? | lfgmarc | OpenFOAM Programming & Development | 19 | November 20, 2013 00:50 |
Compiling new Solver with wmake | lin123 | OpenFOAM | 3 | April 13, 2010 14:18 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
