mesh interface option
Old   October 20, 2014, 11:20
Default mesh interface option
Ema40 is on a distinguished road
Hi everybody.
I have to simulate a water wheel inside a channel. I have some questions and I hope someone will answer me.
1) The rotating domain has an interface in contat with that of the stationary domain (the channel). In the mesh interface option I can't understand which option I have to select among Periodic Boundary Condition, periodic repeat, Coupled wall, Matching or none.
2a) And if I have two different static domain, each of them with a different mesh size? Which option for their interfaces?
2b) In the meshing, it is possible to create on the respective adjacent interfaces the same mesh, in order to have a perfect correspondence?
Very thanks
Ema40 is offline   Reply With Quote
Old   October 21, 2014, 05:53
David Stanbridge
swiftaircraft is on a distinguished road
For the rotating domain then if you have modelled the full 360 degree of the wheel and it is in contact with the fluid domain then you do not need to specify any particular interface treatment. It will just set it up as a non conformal interface. However if you can make sure that the cell size is the same on either side of the interface then this will lead to a more stable solution.
David Stanbridge
Swift TG Solutions Limited
www.swifttgsolutions.com
swiftaircraft is offline   Reply With Quote
Old   October 21, 2014, 11:00
Thank you very much.
mesh interface rotating
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Radiation interface hinca CFX 15 January 26, 2014 18:11
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
