October 19, 2014, 02:01 |
Heat transfer from wall to fluid
uday
Rep Power: 13 |
Hi I am trying to model heat transfer from hot wall to fluid in a 2D channel. Can anybody please suggest me whether I should use simple or coupled wall condition. Also, if I know my heat transfer rate, should heat flux input be sufficient or I have to give high temperature at the wall.
October 19, 2014, 04:57 |
Rick
Rep Power: 27 |
it depends on your domain: if you are modeling the material out of the channel wall the channel wall is coupled and it is automatically created a shadow-wall, otherwise it will be a "simple" wall. If you are modeling the fluid inside the channel and the channel thickness, but not the fluid out of the channel, the internal wall will be coupled, the external "simple", and you'll set bc at the external wall. For thermal boundary conditions you have to input the heat flux or the temperature at wall (in the case of a "simple" wall). |
October 20, 2014, 03:47 |
uday
Rep Power: 13 |
Hi Daniele
Thanks for your reply. I am only modeling the air flow inside the channel at subsonic M. Though I use a simple wall or a coupled wall with high temperature/heat flux as wall b.c; there is not noticeable change in flow properties. I have used very high amount of heat flux and temperature, however the flow properties remain almost same. Should other boundary conditions like wall shear for convection is to be used? Currently I am using no-slip conditions. Can anyone please help? |
October 22, 2014, 10:59 |
usamaraad
Rep Power: 12 |
hi every one
I try to simulate heat pipe by using fluent so can i find the guidance from any one in this subject please please send your answers on my email osamaraad19@yahoo.com thank you for your response >>> |
coupled, heat transfer, wall |
Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 12:49 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 06:25 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
