October 17, 2014, 22:47 |
Problem with visualization of results Fluent
Christian
Rep Power: 13 |
Hi everybody!
I have an issue with post processing. When I finished my simulation, before I open the CFD-Post for see my results, but now, i don't see anything!, only the lines of my geometry, but inside (interior called Symmetry 1 and 2) don't have any solution data stored because when i generate a contour plot, don't show me anything. I reinstall the application, but the issue continue. Any help please? |
October 18, 2014, 03:24 |
#2 | |
Amin
Rep Power: 15 |
Do you active "fill" option? Can you attach a snapshot? |
October 18, 2014, 08:16 |
Christian
Rep Power: 13 |
Of course!
Please, help me |
October 18, 2014, 09:02 |
Rick
Rep Power: 27 |
Are you sure the location is simmetry 1?
Click on the menu location and with the mouse pointer pass over the surfaces (do not click on it), untill the domain is highlighted in green; click on this corresponding surface and plot the contour by clicking on apply button. |
October 18, 2014, 09:14 |
Christian
Rep Power: 13 |
Hi!
Yes, when I pass my mouse over the location, the symmetry is highlighted in green. I saw something, when I select variable velocity u, the contour is showed, but i don't function with Mach number, Pressure, Temperature, etc. If i use the Contour avaliable in Fluent (No CFD-Post), the variable like Mach number, Pressure, Temperature is showed normal. Any suggestion? I begin my project from zero, but nothing! |
October 18, 2014, 09:37 |
Rick
Rep Power: 27 |
Did you try with the file-->export menu?
choose cfd-post compatible, highlight all the cell zones and the quantities you want (temperature, etc) on the right. |
October 18, 2014, 12:11 |
Christian
Rep Power: 13 |
Hi!
I was finding the issue and I finded something. When I export the results on CFD-Post to cvs format, the results is this: But in countour in Fluent, it show me the results. I'm confused. Pd.: Before I compute the results, I select Mach number, Pressure and other variables in Data Quantitaties option. Thanks a lot! |
October 21, 2014, 07:25 |
Christian
Rep Power: 13 |
Hi!
Trying and trying I found that the problem was in Reference Values. A question. What values must to be in Depth and Length? The problem begin when i set Depth in 0 and Length 0, because i thought that for my boundary "outlet" it's correct. Thanks for your help! |
cfd-post, fluent |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 21:08 |
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls | MikeTichondrius | ANSYS Meshing & Geometry | 1 | February 9, 2011 14:31 |
problem about periodic boundary condition in Fluent | winnawinna | FLUENT | 0 | December 29, 2010 00:32 |
