New Surfaces don't show up in contour plotting menu |
October 17, 2014, 18:00 |
Eric
While running a case in Fluent, I ran into problems with the mesh so I went back to ANSYS Mesher, modified the mesh, and created 4 new named surfaces, all of which are symmetry planes. When I go back into Fluent and try to generate contour plots for the new surfaces, they don't show up in the plot menu (or the draw mesh menu either). Only the original list of named surfaces show up. However, they do show up in the boundary condition menu. Any ideas on how to get these new surfaces to show up so that I can make plots? Thanks in advance for any help...
October 18, 2014, 05:37 |
David Stanbridge
Rep Power: 16 |
How did you bring the new mesh into Fluent. Did you reimport the mesh in a standalone fluent run, replace the mesh or did you hit the Setup button in workbench. Using the replace mesh is the best way. If you import through the other ways you can have issues with missing surfaces.
October 20, 2014, 12:10 |
Eric
Thanks for the reply.
I did in fact open Fluent in Workbench using the Setup button. I will try launching Fluent directly and importing the case and data files. |
October 20, 2014, 14:57 |
David Stanbridge
Rep Power: 16 |
The best thing to have done, would be to open the Solution files in serial mode (on assumption that you are not using version 15), then File-Interpolate-Write Data. Then Mesh - Replace. Select the new mesh file in this process. Once it is in and you have scaled it File-Interpolate-Read and Interpolate. Then run an iteration. Stop and save and open in parallel if you have the capability. Otherwise carry on running it in serial.
contour plots, surface |
[ICEM] How to show the area of a surface and the volume inside enclosed surfaces | badboyz31 | ANSYS Meshing & Geometry | 2 | March 23, 2014 02:33 |
contour plot help | jesse@uconn | FLUENT | 0 | February 15, 2010 19:05 |
Vof contour plotting | Shane | FLUENT | 1 | October 8, 2006 04:57 |
cannot show the contour pic | arwang | FLUENT | 2 | May 10, 2004 09:45 |
Plotting Iso Vorticity Surfaces | Radhika Gupta | Main CFD Forum | 6 | June 25, 2001 02:22 |
