calculating thrust of a propeller
Old   October 17, 2014, 09:27
Default calculating thrust of a propeller
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi
i'm working on a quad copter and I want to evaluate the flow field and generated thrust!
so I'm modeled 1/4 of the quadcopter as periodic as appear in the attached picture!
my problem is about calculating thrust of propeller!
How can I calculating generated thrust of a propeller in fluent!?
amin.z is offline   Reply With Quote
Old   October 17, 2014, 09:40
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Originally Posted by amin.z View Post
Hi
I don't know what you mean by "thruster". But if you meant the required power need to rotate impeller, you can do it easily by obtaining torque which can be accessed through Fluent report result tool. Having torque, you can calculate the power. It's straightforward and I did it before. The only thing is that due to modeling only a quarter of the thole model, you have to multiply the result by four to account for required power for the whole tank.
Hope it helps
Regard yours
A CFD free user is offline   Reply With Quote
Old   October 17, 2014, 10:11
amin.z's Avatar
Amin
Hope it helps
I attached a pic to previous post! maybe it helps you find problem out!
it's a vertical take off and landing robot! I need computing generated thrust by each propeller to calculating how many weight robot can lift
Old   October 17, 2014, 10:21
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I think you can calculate the thrust from reports-->forces.
Choose the rotor surface(s) and calculate the force (choose the vertical axis, I cannot indicate if it's x,y or z, axis are not present in the picture).
Daniele
ghost82 is offline   Reply With Quote
Old   October 17, 2014, 10:25
amin.z's Avatar
Amin
Daniele
Tnx dear daniele!
I will check it!
Old   September 15, 2023, 13:51
Fuguś is on a distinguished road
It worked?
Fuguś is offline   Reply With Quote
Propeller Thrust mahdisajjadi FLUENT 1 December 1, 2014 21:24
Propeller thrust stroccel CFX 7 January 12, 2014 06:52
Propeller Thrust distribution cfd_analysis FLUENT 0 July 29, 2013 07:26
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 09:23
