How to create dynamic zone with text commands in Fluent 6.3?
Old   October 14, 2014, 07:36
Unhappy How to create dynamic zone with text commands in Fluent 6.3?
li2150 is on a distinguished road
I saw an old post having exactly the same problem, but I have some further information.
The text command for creating a dynamic zone is define/dynamic-zones/create, then a bunch of information is required. I am using the information in the old post here:
/define/dynamic-zones> creat
Zone name/id [] 17
motion type: (stationary rigid-body deforming user-defined)
enter motion type: [rigid-body] rigid-body
profile/udf [] MovingZone::libudf
cg location x (m) [1.0499994]
cg location y (m) [0]
cg location z (m) [0]
cg orientation theta-x (deg) [0]
cg orientation theta-y (deg) [0]
cg orientation theta-z (deg) [0]
Warning: incorrect cg motion UDF movingzone::libudf on zone 17 (assuming no motion)
MovingZone::libudf is exactly the udf name in the GUI's dropdown list. I also tried these combinations, none of them work:
libudf
MovingZone
libudf::MovingZone
MovingZone::libudf
libudf.dll::MovingZone
MovingZone::libudf.dll
libudf.MovingZone
libudf/MovingZone
[MovingZone::libudf]
Now my barren brain can not even find a possible combination.
Anyone know how to correctly input the profile/udf name? You can save at least two poor people here.
Thank you very much for your reading and help.
BTW: The FLUENT 14 on my campus computer seems all right. I guess this problem only exist in ancient FLUENT versions.
li2150 is offline   Reply With Quote
Old   October 14, 2014, 09:00
ghost82's Avatar
Rick
ghost82 will become famous soon enough
My 2 cents...try to change the name to be lowercase and input movingzone::libudf
ghost82 is offline   Reply With Quote
Old   October 14, 2014, 09:49
Thank you very much for the reply. Although this approach doesn't work, at least this is some new idea.
Actually, the waring message automatically transfer my input to lowercase, I guess maybe FLUENT is not case sensitive?
Old   February 14, 2015, 17:44
Oh no! Four months later, I finally understand your meaning: change the function name in udf file to lowercase and then also input lower case in FLUENT! Yes, this approach works!
I think FLUENT transfer all input in TUI into lower case, but keep the original case from UDF. So they never match. This is a good reminder that always using lower case in FLUENT anywhere.
Old   February 15, 2015, 11:51
ghost82's Avatar
Rick
Thanks for reporting back. Saved after 4 months!
Google is your friend and the same for the search button!
dynamic mesh zones, fluent 6.3, text command
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
