October 7, 2014, 10:54 |
porous media modelling-images attached
ijaz fazil
Rep Power: 13 |
Hi I'm modelling windturbine using porous jump boundary condition. I assumed the turbine to be a disk and disk is divided into concentric rings. For each ring pressure drop is found and is related to the pressure drop boundary conditon of porous jump( I have found (1/alpha and C2 values for each ring). Now I have following doubts I have outer domain and inner domain. Inner domain is the disk divided into concentric circles. My flow is in the negative z axis. and disk is in the XY plane. Now Do I need to create interface between inner domain and outer domain? Between the concetric rings, do I need to create interface or take it to be interior? I also have a doubt how to select my direction vectors for viscous resistance and intertial resistance? My flow is along z- axis. pls click this link if the image is not clear (http://pho.to/7Pssz) |
actuator disk, porous jump, porous media, porous media input, pressure jump |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 8 | May 30, 2024 02:59 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
Porous media modelling in ANsys | dreamlifter747 | ANSYS | 0 | September 13, 2013 10:29 |
Modelling porous media | Rina | Main CFD Forum | 0 | April 10, 2002 10:01 |
Modelling porous media adjacent to viscous flow | Rina Lum | Main CFD Forum | 1 | March 25, 2002 16:55 |
