Not Converging, reverse flow, roughness height, ABL
Old   October 7, 2014, 06:53
Default Not Converging, reverse flow, roughness height, ABL
Rukiye
Rukiye is on a distinguished road
Hi everyone!
I am simulating airflow around buildings. My domain is quite large (2800mx2800mx400m) and I think the distance between the end of the last building and pressure outlet is acceptable (~600m) since the blockage ratio is about 3% where the heighest building is 65m and the rest are in a range of 18-26m. I am using realizable k-e model with standard wall functions. Residuals: for x,y,z velocity is 10^-7; k and e 10^-6 and for continuity 10^-5.
1- My problem is; even if I reduced the under relaxation factors, I keep receiving that reverse flow and my simulation doesn't converge.
I change several times the mesh (coarser and finer mesh) and kept reducing the max skewness (last 94%). Actually I am not quite sure how to pursue a grid sensitivity analysis, but the mesh seems fine.
2- I would like also to implement sang grain roughness height (ks) and roughness constant (Cs) values according to this study: [Blocken 2007] http://sts.bwk.tue.nl/Blocken/pdf/Pr...simulation.pdf
Fleunt doesn't allow an input larger than 1, for roughness height. Is there anyway to change it?
I appreciate very much any kind of input
Rukiye is offline   Reply With Quote
Solution is converging but have reverse flow on pressure outlet Dinesh_Dhande Main CFD Forum 2 March 11, 2018 02:02
momentum & x-vel convergence, and reverse flow problem cinwendy FLUENT 0 April 17, 2013 03:19
Modelling roughness with a laminar flow in Fluent 1000sh Main CFD Forum 0 April 16, 2010 15:41
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 10:14
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
