October 3, 2014, 05:51 |
Fluent analysis for an airfoil
Pratik
Rep Power: 11 |
I am trying to solve for the flow characteristics and the forces on an airfoil in Fluent. It is a 2D analysis. The mesh is a structured mesh. I used a symmetric airfoil to find out which solution method would give me the best results because i know that for a symmetric airfoil the lift is zero at an angle of attack equal to zero ( ideally ). But for some reason (this is where i need help), none of the methods ( solution methods) gave me a lift close to zero. For the airfoil i used, the Chord length was 5.16m and the maximum thickness of airfoil was 0.78m. The velocity of wind was taken to be 100 m/s. For most of the methods( most of them were momentum defined by First order upwind ) yielded a Drag force which was approximately equal to 2352 N and a lift force that was equal to 23659 N. In the reference values in the solution setup, these were the values i entered : Area : 0.78 m^2 Depth : 5.16 m Length : 1 m. Are the values that I have entered for Reference values correct ? Can anyone please tell me what my mistake is? Thanks a lot! |
October 7, 2014, 10:43 |
David Stanbridge
Rep Power: 16 |
You need to provide the boundary conditions for the model. Posting a picture of the mesh would also help in understanding your set up.
October 7, 2014, 13:15 |
Kushal Puri
Rep Power: 12 |
what about the total temperature, pressure and static temperture and pressure.
Its a compressible flow simulation or incompressible |
airfoil, airfoil analysis |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Surface Pressure Gradient at Heaving Airfoil in ANSYS Fluent | saifullahkhalid | FLUENT | 0 | November 11, 2013 04:17 |
Acoustic Analysis using Fluent and ANSYS mechanical | ankit1512 | ANSYS | 0 | November 10, 2013 18:46 |
Acoutic fan analysis | arunraj | CFX | 3 | October 4, 2012 18:54 |
quasi steady analysis of 2d airfoil (pitching) | Alex | FLUENT | 1 | February 10, 2006 02:54 |
