Divergence with Simulation using Embedded LES |
Carlos G. Ramirez R.
Rep Power: 11 ![]() |
Hello All,
I have problems of divergence whit my simulation in Fluent. My case is about a High Lift Configuration (see http://hiliftpw.larc.nasa.gov/). I am using Embedded LES for this simulation, with SST k-omega for the URANS part, and Smagorinsky-Lily for the LES part. For the interface RANS to LES I am using the Vortex method. I've checked the Boundary conditions and these are good for my case, but in te calculation, the simulation diverges in the first iteration. What can i do to get rid of that problem? Any suggestions? Regards, Carlos Ramirez |
Rep Power: 13 ![]() |
There can be dozens of reasons for divergence, post you geometry and mesh maybe to start with, also although i am no expert but LES should not really be used for simulations, there are too many complexities associated with it and for general flows rans based model would suffice. leave the LES for NASA.
While i do not agree with the previous poster on not doing LES, i agree that you should maybe first try RANS/U-RANS on the same grid and see what happens. Then switch to LES
Thanks for your reposts. I tried run the simulation only with the URANS and the simulation diverges too. I think that the divergence in my case is in the problem itself, that it's complex. My case have a grid with 12'700.000 elements.
divergence amg, embedded les, sst k-omega, zonal model |
Help to make LES simulation faster | Pj. | OpenFOAM Running, Solving & CFD | 14 | December 10, 2019 04:13 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
LES SpalartAllmaras Simulation questions | Matt1986 | OpenFOAM Running, Solving & CFD | 11 | June 15, 2015 06:08 |
Divergence Error in my Simulation | utsavac | FLUENT | 0 | July 2, 2014 03:15 |
LES simulation of vibrating Wing | gtg627e | OpenFOAM Running, Solving & CFD | 0 | September 6, 2007 01:36 |
