UDF for Multiphase euilerian model
Old   September 28, 2014, 06:40
Default UDF for Multiphase euilerian model
pibea is on a distinguished road
Hi
I am conducting the two-phase eulerian model computaion.
In my model, the primary phase is CO2 gas and the secondary phase is dry-ice(CO2 solid).(I gave almost properties of dry-ice material manually)
I want to make the secondary phase(dry-ice) sublimate and change the primary phase(CO2 gas).
I heard that there is no sublimation model in fluent, so I coded udf for sublimation.
Inlet condition of the primary phase and the secondary phase is velocity inlet, 100m/s and temperature 220K. Outlet has 0Pa, gauge pressure, and 300K.
The model is calculated as a transient case and coupled solver is used.
The aim of my udf code is that if the cell temperature over some temperature criteria, then volume fraction of secondary phase would change 0 and reaction heat calculated by multiplying diappearing secondary phase mass and latent heat would be substracted from the entalphy of primary phase.
When I compiled and loaded my code, there is no problem.
However, when I ran the calculation, warning message('AMG solver divergence detected: pressure coupled' like this messages) is shown and calculation is interrupted.
My code is below,
#include "udf.h"
DEFINE_MASS_TRANSFER(sublimation, cell, thread, from_index, from_species_index, to_index, to_species_index)
Thread *dryice = THREAD_SUB_THREAD(thread, from_index);
Thread *gas = THREAD_SUB_THREAD(thread, to_index);
double Q_sub=575400;
double rho_d = C_R(cell,dryice);
double rho_g = C_R(cell,gas);
double vof_d = C_VOF(cell,dryice);
double vof_g = C_VOF(cell,gas);
double m_dot;
double T_gas=C_T(cell,gas);
double T_dryice=C_T(cell,dryice);
double T_sub=221;
m_dot=0.0;
if (T_dryice > T_sub)
C_VOF(cell,dryice) =0;
C_H(cell,gas) -= Q_sub*vof_d*rho_d/(vof_d*rho_d+vof_g*rho_g);
else if (T_dryice< T_sub)
pibea is offline   Reply With Quote
Old   August 2, 2022, 02:41
numaniqbal444@yahoo.com is on a distinguished road
I want to simulate sublimation process in Fluent.Can you send me your udf code at my email numaniqbal444@yahoo.com
numaniqbal444@yahoo.com is offline   Reply With Quote
Old   June 13, 2023, 22:22
limjw97 is on a distinguished road
Hello Pibea,
Do you solve this problem? I am now working on a similar simulation with yours and struggling with the problem. Could you send me the udf code to my email limjw97@hanyang.ac.kr
limjw97 is offline   Reply With Quote
Old   April 30, 2024, 02:25
Aneesh
aneesham75 is on a distinguished road
I am also doing the same problem. It would be helpful for me if you send the code to my mail( aneesham7589@gmail.com)
aneesham75 is offline   Reply With Quote
udf for Srivastava and Sundaresan friction model Musa FLUENT 1 March 14, 2014 03:42
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
Why my UDF doesn't work when I activate the non-premixed combustion species model? TMorgado Fluent UDF and Scheme Programming 0 February 5, 2013 15:09
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
UDF: how to know domain number in the model? mssound FLUENT 0 May 17, 2010 16:00
