Problem simulating natural convection tall cavity
Old   September 24, 2014, 17:11
Unhappy Problem simulating natural convection tall cavity
Natalia
natalialissette is on a distinguished road
I hope someone can help me.
I'm trying to simulate natural convection in a tall vertical annuli cavity. Height is 0.215 m, outer cylinder is 0.15 m, and inner cylinder is 0.03 m in diameter.
My mesh is al hexahedral 2D, with 70700 elements. My model is 2D axysimetric. There are more than 30 elements in the region of the boundary layer.
Gravity is -9.81 in X. I'm using double precision in Fluent. Pressure-based solver, steady. I'm using SST k-omega with low Re-correction. I'm doing the boussinesq approximation stating operating density and a compresibility coefficient. Fluid is water.
The boundary conditions are uniform heat flux 440 w/m^2K in the inner wall and -176 W/m^2K for the outer wall. The Rayleigh number is 10^8. Scheme SIMPLE, Spatial discretization for pressure is PRESTO!, second order upwind for momentum, turbulence, dissipation and energy. All relaxation factors are default. I doesn't converge. k is constanlty diverging.
I also tried transient approaches and it seems to converge only at low Ra numbers. I have tried other solvers, and other models for viscosity and nothing seems to work.
Can someone give me suggestions??
Thanks in advance
natalialissette is offline   Reply With Quote
boussinesq approximation, fluent, high rayleigh numbers, natural convection, tall cavity
convergence problem in natural convection paps ANSYS 0 December 1, 2013 06:04
Natural convection in cavity heated by below Nanbrain Main CFD Forum 0 January 28, 2013 08:49
how to set the parameters in simulating the natural convection hook FLUENT 1 January 17, 2010 02:33
Radiative heat transfer with natural convection inside a square cavity msarkar OpenFOAM 1 January 11, 2010 23:21
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM varghese FLUENT 6 February 6, 2002 06:23
