Need experience comment on cavitation combine energy equation!!!
Old   September 24, 2014, 11:28
Default Need experience comment on cavitation combine energy equation!!!
le hoang anh
lehoanganh07 is on a distinguished road
Hi, I did the numerical simualation fir nozzle cavitating flow without thermal effect. Now I want to account the effect of thermal property on cavity. To do this, I change the vapor density to ideal gas and viscosity. Also the vapor pressure is the function of temperature. By enable the energy option, the energy equation is calculated with other equation.
But the result is different to experimental results and the results without thermal effect, It is longer than the other one, the cavity length. This chacracteristic is incorrect, due to thermal effect the cavity should be shorter.
So it seem to be that the cavitation with energy equation is not compatible in Fluent?
Someone has experience in this research, please help me to answer my question? Thank you.
lehoanganh07 is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Solving the total energy equation dohnie OpenFOAM 21 June 13, 2014 01:44
rhoCentralFoam: making sense of the diffusive corrector equation for energy tatu OpenFOAM Running, Solving & CFD 5 February 19, 2013 09:19
simpleFoam with energy equation sega OpenFOAM Programming & Development 6 January 26, 2013 07:42
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 07:06
