how to incorporate the temperature of fluid in pressure based cavitation model
Like Tree4Likes
Old   September 23, 2014, 11:51
Default how to incorporate the temperature of fluid in pressure based cavitation model
arindamsantra7 is on a distinguished road
I want to simulate a cavitation model in a converging-diverging nozzle.
I use the mixture model where the primary phase is water liquid & the secondary phase is water vapour. the inlet pressure is 248 kpa & the outlet pressure is 101 kpa. the mass flow is 8.78 kg per sec. the temp of the fluid at inlet is 370k. due to heat is not absorbed or released by the fluid throughout the system. we can assume the temp is constant throughout the system, that is 400 k. but I can not incorporate the temp in this model. because there is no option to give the temp in pressure inlet & pressure outlet based cavitation model. So I want to know, how I can incorporate the temp of the fluid in this cavitation model
arindamsantra7 is offline   Reply With Quote
Old   September 23, 2014, 12:16
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I don't understand your question...you are stating that:
- we can assume the temp is constant throughout the system, that is 400 k
- So I want to know, how I can incorporate the temp of the fluid in this cavitation mode
If you want to simulate at constant temperature all you need to do is to specify the fluid properties at that temperature, you don't need to set temperature in fluent; this means you have to set constant density, viscosity, vaporization pressure and surface tension (for Singhal et al model), which are unique values at that operating temperature.
thermal energy likes this.
ghost82 is offline   Reply With Quote
Old   September 24, 2014, 04:08
Originally Posted by ghost82 View Post
thank you sir for your kind information.
sorry, I give the wrong temp. the right temp is 370k. I get the constant density, viscosity, vaporization pressure and surface tension at this temp for water liquid. but how I can get the density & viscosity of water vapour at this temp? please specify the equation from where I can get the density & viscosity for water vapour at specific temp.
Old   September 24, 2014, 05:07
ghost82's Avatar
Rick
You need to calculate saturated steam properties at that vapor pressure/temperature (370 K).
You can use for example this calculator:
http://www.peacesoftware.de/einigewe...r_dampf_e.html
Input the temperature (370 K) in the box "Calculation of thermodynamic properties of saturated steam".
You will have:
vaporization pressure: 90535,51 Pa
Water:
density: 960,59 kg/m3
dynamic viscosity: 0,00029 Pa*s
surface tension: 0,05987 N/m (ref. http://www.nist.gov/data/PDFfiles/jpcrd231.pdf)
Steam:
density: 0,538 kg/m3
dynamic viscosity: 1,216E-05 Pa*s
Old   September 24, 2014, 06:33
thank you sir, I got your answer. But I want to know the relation or equation from where I can solve manually the value of the density & viscosity of water vapor at a specific temp
Old   September 24, 2014, 06:34
You will have:
Water:
Steam:
Old   September 24, 2014, 06:45
ghost82's Avatar
Rick
If you treat steam as ideal gas, ideal gas equation for density and Sutherland equation for viscosity (for example).
Old   October 17, 2014, 02:00
ideal gas equation is pv=nRT. In this problem pressure is varying throughout from inlet to outlet. so, what pressure value I have to choose to solve the ideal gas equation to get the vapour density.
what is the formula for this case to calculate the turbulent intensity percentage.
Last edited by wyldckat; November 1, 2014 at 08:53. Reason: posted few minutes apart
Old   October 17, 2014, 04:38
ghost82's Avatar
Rick
As I wrote some posts above, the vapor is saturated; so pressure in the ideal gas equation is the vapor pressure at the calculated temperature.
Turbulent intensity is defined as the ratio of the root mean square of the velocity fluctuations, to the mean free stream velocity.
Old   October 17, 2014, 07:29
thank you sir
Old   October 30, 2014, 10:58
the inlet & outlet diameter of converging-diverging nozzle is 51.2 mm. the throat diameter is 25.6 mm. mass flow at inlet is 8.75 kg/sec. the density of water at 373 k is 958.462. so the velocity of water at inlet is calculated as 4.4341 m/sec. Reynolds number at inlet is calculated as 771095.9264 by taking kinematic viscosity at 373 k is 0.2944198 x 10^-6 & hydraulic diameter 51.2 mm.
Is the reynolds number calculation is right ?
& can I use this formula for turbulent intensity calculation?
I= 0.16 x (Re)^(-1/8)
Old   October 30, 2014, 11:35
ghost82's Avatar
Rick
If these are the data for inlet Re number is correct.
But I don't think the input data are correct..have you boiling water at venturi exit??
Old   October 30, 2014, 14:20
in this case the pressure inlet is 555 kpa & outlet pressure is 378 kpa.
so then the input data are correct or not?
if the reynolds number calculation is right, then please specify that the above turbulent intensity percentage calculation formula is applicable or not ?
Old   October 30, 2014, 14:29
ghost82's Avatar
Rick
That formula refers to internal duct fully developed flow so if this is the case it is correct.
Google is your friend and the same for the search button!
Old   October 30, 2014, 15:34
what is the momentum equation for this case?
Old   October 30, 2014, 15:38
ghost82's Avatar
Rick
Refer to fluent user guide.
Old   October 31, 2014, 08:00
I give all the data as per I told previously. but the calculation show that divergence occurs. which I have to adjust now to converge the solution.
Old   November 3, 2014, 04:41
In this calculation I get the reversed flow in several faces & it is still after the 3000 iterations. what adjustment I have to do.
Old   November 6, 2014, 12:31
You will have:
Water:
Steam:
what is the uses of residual factors?
Old   November 12, 2014, 00:36
You will have:
Water:
Steam:
Respected sir,
I have done the simulation by taking the water as working fluid. But now I want to do the simulation by taking the diesel fuel as working fluid. So, please tell how I can get the properties of diesel fuel at 300 k & at other temperature.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
