Problem reading profile
Old   September 18, 2014, 14:05
Default Problem reading profile
Francisco
Bollonga is on a distinguished road
Hi everybody:
Just a little question.
I'm trying to read a profile file which defines the x-position and angle of rotation in the z-axis from the menu File/Read/profile. But I don't know why Fluent is not able to read it, it just gets stuck with the message "Reading profile file ..."
I've used the transient tabular profile format. (see here: http://aerojet.engr.ucdavis.edu/flue...ug/node213.htm)
I can only read it with the command File/read-transient-table
Is it not posible to read a transient-table format profile directly?
Thanks a lot!
Bollonga is offline   Reply With Quote
Old   September 19, 2014, 06:10
HHOS is on a distinguished road
I don't exactly know what problem you have, but when I have to deal with profiles I do the following:
-Just initialize the case and write the profile of what you will want to read in.
-Check the profile picture you generated, and take a look at the structure of it.
-Fit that structure with your profile.
Regards
PS: Probablemente sepas más de CFD que yo, no sé si la respuesta es demasiado obvia.
HHOS is offline   Reply With Quote
Old   September 22, 2014, 09:10
Francisco
Hola HHOS:
My only problem is how to read a profile (3D path in my case) in a transient table format directly from the menu, as I am only able to read it from the command prompt with the command "file/read-transient-file".
By the way, what do yo mean here with structure and fitting it to the profile?
Old   March 8, 2024, 19:59
JStew is on a distinguished road
That happens to me when I accidentally specify the wrong number of entries in the ttab profile file. In the below example, I put "6" instead of "7" for the number of rows, and ansys got stuck "reading" the data - I guess the developers didn't put in error statements for this process.
transient_profile 2 7 0
time heat_source
0 0
1 5
2 6
3 7
4 8
5 9
6 14
JStew is offline   Reply With Quote
Problem with reading CSV files MrNinainaidi OpenFOAM Running, Solving & CFD 1 July 2, 2015 06:34
pressure contour and velocity profile problem alee1293 Main CFD Forum 0 July 18, 2014 11:31
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem reading .cas because of UDFs Star-Fluent-X FLUENT 2 February 12, 2009 11:01
